Load transfer between interacting surfaces
Dear colleagues,
I'm developing an abaqus model for a metal - composite single lapped bolted joint.
I'm simulating a simple shear test of this joint and I need to calculate the load transfer through the bolt and through the interacting surfaces.
Which is the abaqus function suitable for the prediction of the load transferred between different interacting surfaces?
Any suggestion will be highly appreciated!!!
Simone
Simone
RE: Load transfer between interacting surfaces
I would like to calculate the load transferred through the bolt and through the surfaces but I don't know how to do it.
The bolt has the correct preload and I expect to see that for very low applied loads there is a load transfer through the two surfaces (interacting through friction) and then, as soon as the load increases, all the load is transferred through the bolt. Do you have any suggestion?
Are you new to this forum? If so, please read these FAQ:
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
