Using springs to measure twisting of foundations
hi,
I am trying to model how a 3D foundation for a bridge twists under loading. It is prevented from displacing in the vertical direction, but can twist in the other direction. I initially tried to put 4 springs in at the four corners of the end face of the foundation. In this way, one end of the foundation could displace more if it had a greater force. However, I cant get this to work. I am doing an explicit analysis and I am having trouble connecting the other end of the spring to a fixed point in the part. I was able to use a reference point for this, but I can only seem to create one per reference point per part, and I need four reference points. Anyone have any suggestions on how I can model this?
RE: Using springs to measure twisting of foundations
Are you using rigid bodies or something?
If not, just use connectors with spring behavior, or the *spring option (maybe the spring is only for standard, idk)
Yeah I have tried to use the connectors now, they seem much easier. However, it asks me for a D value, when I choose elastic behaviour for the connector. I have checked through the manual, but I dont know what D is. I was expecting a stiffness (E) value instead. Do you know anything about this?
Just do per component:
Data lines to define linear uncoupled elastic behavior (the COMPONENT parameter is included and the NONLINEAR parameter is omitted):
First line:
Elastic stiffness (force or moment per relative displacement or rotation; force for SLIPRING).
see:
31.2.2 Connector elastic behavior
the D (21 value matrix) is for coupled unsymmetric linear stiffness, which you probably don't need.
I have attached a screenshot of the connector section that I have developed. I think I have to put in a D11 value that represents the elastic stiffness. I have run this model but even for a very low stiffness value, the foundation did not move much, which makes me think something is not correct. Is that connector section okay?
an axial connector is exactly what it says it is, a connection that only allows movement in the axial direction (for the value 1 this is 1 force per length).
Are you sure you don't want e.g. a cartesian connector (with 3 stiffness values for each of the 3 directions)?
Also check your units for consistency.
Other than that, we will need more info (e.g. an input file)
Well I have put the axial connectors in the two directions that I want the foundation to twist (see the screenshot attached). I am still a bit confused about the D11 value. It is a stiffness value yes? Is 1 a very low value or not?
by twist you mean rotate? Then you should use a rotational connector and rotational stiffness.
And D11 is a stiffness value, abaqus is unitless so I don't know if 1 is low or not.
I am currently running the axial connectors I had before, but going for the non-linear option. I am only putting in one line in the data so its actually behaving linearly (I just put in a force and displacement). I tried changing the D11 value in the linear model but it didnt seem to make any difference. I would use the rotational connector, but im not sure which moment (M1, M2 or M3) to use?
