Uplift pressures on dams
I am trying to analyze the uplift pressures on a dam and compare them with the overburden pressure or applied pressure in order verify how safe would it be.
I am using a finite element software for computing the uplift pressures.
As an example my max uplift pressure value is around 60 kPa (60 kN / m2), which occurs somewhere in the mid section of the dam. I understand it is 60 kN / (1 mt perpendicular to the analysis x 1 m along the section).
In this case, applied pressure on that specific point would be the concrete unit weight (it is a concrete dam) x (1 mt perpendicular to the analysis x 1 m along the section). This confusion arised as by overburden or applied pressure any person would understand gammma x height, but this last concept is not applied as it was for the max uplift pressure computed by the software.
Is this a correct assumption?, please let me know. I haven't see any clear example about this.
Another thing, is there minimum required FS agains uplift in dams?, I have few books but none specify any minimum FS required.
RE: Uplift pressures on dams
first, determine if your dam is a jurisdictional structure, if it is than you must get a permit from the regulatory agency and they will set the FS. they will also gladly help with non-jurisdictional dams. If you are in the US, than visit this site:
http://asdso.org/ or
http://ussdams.org/
if all that fails, the US Army Corps of Engineers has published guidelines that are widely accepted
http://140.194.76.129/publications/eng-manuals/EM_...
