Title Block Design
Title Block Design
I am in the process of designing a new title block. Currently a pattern is brought in for the block geometry and the field are all populated by notes where some reference expressions.
Instead of trying to make my old ways work, what other options are there if I were want to start fresh with a new method. We are on NX 7.5 and Teamcenter 8.3. Any suggestions for a better block are appreciated.
RE: Title Block Design
Below is an example of Drawing Border with an included Title Block which was constructed virtually 100% with the new NX 8.0 tools. The only items that I had to manually add the Drawing template was the projection symbol in the upper-left corner, the notation in the lower-left which is a 'smart note' showing the file name of the 'master model', the 'Drawing Sheet' designation in the lower-right, which again consists of 'smart text' showing the current sheet number as well as the total sheets and finally the 'logo' which is an image file placed on the Drawing template. And while it did have to add the Parts List note, it was a previously created Parts List template which I simply integrated into the finished Drawing Template file. Granted, this is a simplified 'Drawing Border' created specifically for demos, but it does take advantage of most all of the capabilities of the new tool. What I mean is that except for the items noted above, EVERTHING ELSE THAT YOU SEE was created BY THE NEW TOOL Drawing Border and Title Block tools themselves and did not require the I construct anypart of the artwork or the text as separate objects.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
