access violation,
access violation,
While working on a drawing I got booted out of AutoCad 14 back to desktop. Now everytime I try to load this one drawing I get booted back to desktop. Only this one drawing, no others. Also got this message, not every time - "access violation 0xc000005 address 0x77f6ce0c". Anyone know how to fix this?
RE: access violation,
Use drawing recovery to try to purge the bad voodoo.
If that fails, open a new drawing and insert the suspect drawing as an exploded block.
If that fails, and you have access to Map, query in all the objects in draw mode into your session. I've seen this work when the above fails.
If that fails, try opening the problem file in Intellicad and save as a new name.
Failing all else, e-mail the problem file to me (zipped) and I'll give it a wack.
karlfuls@home.com
