Why does the torque output of a DC motor decrease linearly with RPM?
I know this applies to brushed DC motors and I think it applies to brushless as well?
RE: Why does the torque output of a DC motor decrease linearly with RPM?
Keith Cress
It represents a counter voltage developed by the spinning armature.
Keith Cress
V = Ke*w + R*I
where:
V is the voltage across the leads (constant applied in your case);
Ke is the back-EMF constant of the motor (volts per unit speed);
w (omega) is the angular velocity;
R is the resistance;
I is the current
The higher the motor speed, the more of the supply voltage is "used up" by the back-EMF term, and the less is available to drive current through the motor. Since torque is proportional to current, as your speed increases, your torque generation capability decreases linearly.
T=Kt*I where Kt is same thing as Ke but in different units (torque/amp)
So studying them together one can see as the voltage is used up to make speed, less is left over to make I (V/R).
So as Curt showed, the faster you go with a constant voltage applied, the less is left over to make current in the motor resistance, hence less torque as u go faster.
So you see you stated it backwards by now; torque does NOT go down as speed goes down, but rather as it goes up.
So how about brushless DC or PM AC motors? Is it the same deal?
Just to toss in a little more the Horsepower is a direct function of the speed times the torque.
Keith Cress
