Naming arrays with for loop?
Dim MainArray(999,3)
Dim i As integer
For i = 1 to partcount
Set MainArray(i-1,0) = products1.Item(i) 'The first row of the MainArray consists of the products of the PPR
Next
Dim P0(11)
MainArray(0,0).Position.GetComponents P0 'Using the GetComponents method an array named P0 is created and contains the coordinates of the product MainArray(0,0)
MainArray(0,1)=P0(9)
MainArray(0,2)=P0(10)
MainArray(0,3)=P0(11)
This is a part of my code that works fine, but i want it to work
From P0 to P(partcount) and i wonder if i can use a for loop at the name of the array?
Something like that:
For i=1 To partcount
Dim P"i"(11)
MainArray(i,0).Position.GetComponents P"i"
MainArray(i,1)=P"i"(9)
MainArray(i,2)=P"i"(10)
MainArray(i,3)=P"i"(11)
Next
Any help or alternative choice would be very helpful!
Dim i As integer
Next
Dim P0(11)
Dim P"i"(11)
Next
