Drafting: Basic dimensions
Hi everyone!
I am having some troubles with reading drafts, and I hoped someone here could help me out. When defining a positional tolerance (let's say a hole center), one must define it with respect to some reference features (namely datum planes or surfaces), and define also some basic dimensions. Those basic dimensions are theoretically exact dimensions with no tolerance associated. Ok, so far so good. However, they must have an allowed tolerance in order to be manufactured.
My problem is that we just bought some measurement equipment, and I want to know if I can measure those basic dimensions with our equipment. I have gone through ISO 2768 (both parts), ISO 1101 and DIN 7168, but didn't find anything useful besides a comment saying "tighter tolerances shall be applied to these basic dimensions".
Drafting is not my area of expertise, so I don't know whether I should control those basic dimensions in a dimensional control or skip them.
Best regards!
Best regards!
RE: Drafting: Basic dimensions
"Where basic dimensions are used, associated tolerances contain the number of decimal places necessary for control." And the following figure shows a ø0.15 positional tolerance associated to a 25 mm dimension. Does that mean that to control that 25 mm dimension I need 0.01 accuracy or 0.001?
if the dim'n is to 1 deciminal place, then the tolerance is +- 0.1",
2 places, +- 0.03"
3 places +- 0.01"
Quando Omni Flunkus Moritati
Sorry rb1957 but if basic dimensions are being used then the block tolerances like you suggest have nothing to do with it.
The tolerance on those basic dimensions is given by the geometric controls in the feature control frames - that is the position tolerance or surface profile etc. The basic dimensions give the perfect target location, the geometric control then says how far the feature can deviate from that location.
bibayoymicabayo when referencing Y14.5 you need to say which year version as there can be differences.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Regarding the Y14.5, it is '09 version.
The thing is that the equipment software allows me to define the nominal position of the features I want to control, but it makes me insert a tolerance (and does not allow it to be 0). Thus I don't know whether that has any influence in a positional tolerance or not, for example. But I guess this is a question to ask to the equipment support service...
If your software doing a pass/fail test? If so, the tolerance is absolutely necessary. If you have basic dimensions, look for feature control frames.
I do not know how your machine or its software works. You should read the ASME Y14.5 standard and understand how datums are defined. If a datum is a plane, I would hope you could rub your cursor over the surface, and the program would figure out where the datum was. You can read up on datum targets, and tell your drafters how much you like them.
If your machine "knows" the datums, the type of tolerance and the value, it should be able to tell you if the feature passes.
JHG
I thought to do it properly you had to derive it from an inspection fixture (granite plate etc.)to better simulate the 3/2/1 contact points.
I don't know. According to ASME Y14.5, if the datum is applied to a flat plane, the datum plane is defined by the three points sticking out the furthest. You would have to find these points by rubbing the face with your probe, and letting the software work out where the points are. What fun it will be if the part is concave. If you are confident that the part is flat, you can tap three arbitrary points.
Datum targets create several opportunities to make all of these easy to implement.
JHG
As long as the face is not concave. A fixture works nicely with datum targets.
JHG
Drafting Standards, GD&T & Tolerance Analysis
http://www.eng-tips.com/threadminder.cfm?pid=1103
Regards, Wil Taylor
Trust - But Verify!
We believe to be true what we prefer to be true.
For those who believe, no proof is required; for those who cannot believe, no proof is possible.
