Worm Gearbox efficiencies for hoists during raising/lowering
Hello
I'm trying to determine if there is any difference in efficiences for a worm gear box used in a hoist system.
Details are as follows:
A hoist is used to lift a gate. The hoist drive train is composed of a 25hp motor, primary reducer (worm gearbox with 1/60 gear ratio) and two secondary reducers driven wire rope drums (one off each side of the worm). As the worm gearbox is self locking at this ratio, a torque input is required to lower the gate. Is the efficiency of the worm gearbox the same whether the gate is lowered or raised? I have not found any vendor information that clarifies this.
Anyone have any experience with this? Any incite or references would be greatly appreciated.
RE: Worm Gearbox efficiencies for hoists during raising/lowering
You might want to try the FBD using your pressure angle and lead angle. You might find there's not much difference.
