Meaning of "Target Thickness" When Using "Automatic..." Midsurfacing
What does "target thickness" mean, exactly, when mid-surfacing a solid with multiple thicknesses?
I notice that this input directly effects how it is mid-surfaced, and would sometimes fail the operation if not inputted correctly.
i.e. In one example, using a C channel (without fillets or rounds) with a web thickness of 0.29" and arm thickness of 0.47", the larger (0.47") thickness successfully produced a mid-surfaced solid with the C profile. Though, when I specified the target thickness of the web (0.29"), only the webbed portion of the solid mid-surfaced.
Does that mean only use the largest "thickness" of the solid?
I'd appreciate the clarification.
Thanks in advance:)
Thanks in advance:)
RE: Meaning of "Target Thickness" When Using "Automatic..." Midsurfacing
Target Thickness means "midsurface tolerance". Any surfaces with a distance equal or less than the target thickness will have a midsurface generated. The command then intersects all created midsurfaces with one another and lastly, deletes all small free floating surfaces.
Best regards,
Blas.
Blas Molero Hidalgo
Ingeniero Industrial
Director
IBERISA
48011 BILBAO (SPAIN)
WEB: http://www.iberisa.com
Blog de FEMAP & NX Nastran: http://iberisa.wordpress.com/
What about slicing your solid (C-channel) in multiple parts and doing the mid-surface for each part ?
