Mod to Journal
Mod to Journal
Mod to Journal
Hi Everyone, I've had some help with some journals which I real appreciate. However i have a question about the attached journal. I've modified a standard version of this file, so it adds extra columns with appropriate tolerances and all this, but my question is can I make it read from a specific axis system? I've been through it and had a play, but can't seem to change it so it works. Not sure if it could be changed so it picks up a name of a system, so for example i name a axis system 'Dave' and then edit the appropriate part of the program to pick up axis system 'Dave' and produce co-ords from there.
Any help would be great.
Thanks in advance.
RE: Mod to Journal
Engineering.com doesn't like the ampersand (&) in your file name.
www.nxjournaling.com
RE: Mod to Journal
Can you rename & upload the file again.
regards,
Sundeep
RE: Mod to Journal
The function, UF_CSYS_map_point, will convert points from the absolute coordinate system to the work coordinate system (or vice versa). A code example can be seen here: thread561-325985: Change Global Co-ordinates to Local Co-ordinates using NXOpen?
Unfortunately, you can't pass in a saved csys to the function; it seems to only work with the absolute and work coordinate systems. You may have to do a little extra work like moving the WCS to the saved csys before calling the function.
RE: Mod to Journal
Hi, sorry not reported back. Not got round to trying it out yet. Will do when I get chance. Been put back on Catia V5 for a bit! Yawn........ Thanks for the reply tuough I do appreciate it.
