Can Steam with high pressure air be effective?
I want to use high pressure steam(50 bar, 280 degree cel.) in a reactor to mix with waste,
can we achieve the same effectivity as that of the steam with the mixture of inferior steam and pressurised air?
(There is a possibility that the steam might condense as it comes into contact with the air but for reducing this possibility we can preheat the air so that steam quality and its temp. is not affected)
-regards
-regards
RE: Can Steam with high pressure air be effective?
If you don't have steam on site, then you will be paying (a lot) for the electricity and compressor run time to compress low pressure air into high pressure air.
Do you want a high pressure but cold gas that doesn't condense into a low volume, low temperature fluid;
or a high pressure high temperature gas that does condenses;
or a high temperature high energy gas mix that you can't mix into your condensate water;
