MIL-STD Steel Groupings A-36 Equivalent
Hi all,
I am looking for some answers on Mil-Std 278. In the base metal grouping table there is no listing for A36 plate steel. Does someone know what the MIL-STD eqivalent to A36 steel would be? In group"S-1" in the table it shows carbon steel so I am assuming it should be within this group. There are other ASTM grades listed along with the MIL-STD classifications.
Thanks in advance!
Thanks in advance!
RE: MIL-STD Steel Groupings A-36 Equivalent
You will need to review the requirements contained in MIL-S-22698C to verify the application will allow the substation and use of ASTM A36.
Best regards - Al
So if I'm reading it correctly A36 is listed for use as bars and bar size shapes only limited to 3/4" like you said.
For ordinary strength structural steel such as plates, I would need to spec out "ABS grade A" or "ABS grade B" instead of A36 as stated in 1.2.1 unless approval is sought for usage of A36 plate?
Best regards - Al
Since we're talking MIL-STD, the customer would like metal core wire to be used but I am not finding any on the filler metal chart Table 2 in Mil-Std 278. It seems to me that I would have to seek approval for the usage of this. I am going off of a 1995 revision of the standard so I am just wondering if there have been updates that would apply to the usage of metal core wire.
