Leaking PSVs
Leaking PSVs
Our company is doing a PSV audit for a client and they would like PSVs that are leaking to have size verification done. Is this necessary? I was wondering what other opinions are on this?
Thanks!
Thanks!
RE: Leaking PSVs
RE: Leaking PSVs
If a psv is leaking it either needs to be fixed or means you are very close to it's set point or has lifted and not reset properly.
Size or capacity has nothing to do with "leaking" so I just don't understand the issue.
What sort of audit is it?
RE: Leaking PSVs
If we are to find a PSV that is leaking, the client would like us to verify the original engineering design to make sure that the proper PSV was installed for the application. To do this, they'd like us to confirm that the PSV has the proper orifice designation and relieving capacity at set pressure.
I hope that makes a little more sense!
RE: Leaking PSVs
I would suggest that if you find one that is leaking, then note it's supposed set pressure on the name plate, the operating pressure of the line at the time and the design pressure of the relevant line. Then you can see if the operating pressure is too close to the set pressure (normally ~10% below set pressure, but can be less if you have a pilot operated valve) or whether the valve is passing when it shouldn't, hence needs to be maintained and set pressure checked.
To work out what the capacity should be needs a comprehensive review of the process safety calcs, which is not a straightforward task, but unless you've made some serios modifications to the plant since the design, shouldn't be an issue. Still nothing to do with leaking valves though.
I would double check what the client actually wants from this survey in this respect because it sure doesn't make sense to me.
RE: Leaking PSVs
