NX Beginner - Problem with Sketches to 3D View
I am a beginner to NX Unigraphics, but I am familiar with Autodesk Inventor Pro. I am having a problem where when I try to sketch something and then finish the sketch to go to the 3D view, I am left with breaks in my profile even though my profile is closed in my sketch. For example:
I have made my sketch of a 100 by 150 rectangle: http://i44.tinypic.com/9r3srd.png
I then click "Finish Sketch" and get the following image. Note how it is not complete: http://i40.tinypic.com/2uxwcg8.jpg
I have tried to use the rectangle command, but I get the same result. Also, I have performed the extrusion I want without problems a few times, but occasionally I get this problem. I suspect there is an issue with how I am using the software. Any help with this would be greatly appreciated.
RE: NX Beginner - Problem with Sketches to 3D View
Perform a 'Fit' operation after you finish your sketch.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
It is possibly a view clipping issue. When you see this happen, try pressing the "Home" key on your keyboard; it will reorient your view to trimetric, and more importantly, it will reset the view clipping planes.
www.nxjournaling.com
