What am I doing wrong here!?! (Renaming instances)
HI Guys,
Pulling my hair out here, because whatever I do I cannot get instances within a component to rename.
Essentially I have a product with a component at the end of the tree with loads more parts inserted in there.
This code drills down to it and then renames them sequentially:
CODE
Sub CATMain()
    Set oDocument = CATIA.ActiveDocument
    Set oProduct = oDocument.Product
    Set oProducts = oProduct.Products
    Set oProducts = oProduct.Products.Item(oProduct.Products.Count).Products
    'Rename Instances Sequentially
    For i = 1 To oProducts.Count
        Set ProductRename = oProducts.Item(i)
        ProductRename.Name = i
    Next
End Sub
However, nothing happens. No error, no nothing. Not even " ProductRename.Name = "TEST" " results in anything!!!
CODE
    Next
Works perfectly at the upper level (Set oProducts = oProduct.Products).
Any thoughts on what I'm doing wrong? dazed
RE: What am I doing wrong here!?! (Renaming instances)
Try adding ReferenceProduct:
Set product2 = oProducts.Item(2).Referenceproduct
MsgBox product2.Name
product2.PartNumber = "rename test"
Add something like this to your loop:
Set oProdToRename = Selection.Item(I).Value.ReferenceProduct
oProdToRename.PartNumber = "new part number"
http://excelspreadsheetshelp.blogspot.com - http://scripting4v5.com
Thanks. That worked a treat.
My code is now:
CODE
Sub Test()
    Set oSelection = oDocument.Selection
    Set oConstraints = oProduct.Connections("CATIAConstraints")
    Set oProducts = oProduct.Products.Item(oProduct.Products.Count).ReferenceProduct
        ProductRename.Name = "Item." & i
    Next
    '***** Refix Everything *****
        Set oReference = oProduct.CreateReferenceFromName(oProducts.Item(i).Name & "/!")
        Set oNewFix = oConstraints.AddMonoEltCst(catCstTypeReference, oReference)
        Set oConstraintName = oConstraints.Item(i)
        oConstraintName.Name = "Fix." & i
    Next
End Sub
This works nicely if I'm fixing the root of the product (Set oProducts = oProduct.Products) but it hangs at "Set oNewFix = oConstraints.AddMonoEltCst(catCstTypeReference, oReference)" when using this (Set oProducts = oProduct.Products.Item(oProduct.Products.Count).ReferenceProduct).
Ideas?
Thanks guys!
I found this script ant it renames all Instances even in sub products and/or components
CODE --> CATBVA
Public sPN() As String
Public lCount() As Long
Public lnn As Long
Public bExist As Boolean
Public stempPartNumber As String
Public sPartNumberCache() As String
Public lPartNumberCacheSize As Long
Public bExistInCache As Boolean
          '***  Macro de renommage automatique des instances        ***
Sub CATMain()
lnn = 1
ReDim sPN(lnn)
ReDim lCount(lnn)
sPN(0) = ""
sPN(1) = ""
lCount(0) = 0
lCount(1) = 0
bExist = False
stempPartNumber = ""
lPartNumberCacheSize = 1
ReDim sPartNumberCache(lPartNumberCacheSize)
sPartNumberCache(0) = ""
sPartNumberCache(1) = ""
bExistInCache = False
'Vérifie que le document actif soit un CATProduct
Dim monDocument As Document
On Error Resume Next
Set monDocument = CATIA.ActiveDocument
If Err.Number <> 0 Then
    MsgBox "La fenêtre active doit être un CATProduct"
    Exit Sub
End If
On Error GoTo 0
If TypeName(monDocument) <> "ProductDocument" Then
    Exit Sub
End If
Dim monProduit As Product
Set monProduit = monDocument.Product
If monProduit.Products.Count > 0 Then
        Call fSetProductName(monProduit, monDocument)
Else
        MsgBox "Ce produit est vide!"
End If
End Sub
Function fSetProductName(monProduit As Product, monDocument As Document)
Dim otempProduct As AnyObject
For i = 1 To monProduit.Products.Count
    stempPartNumber = monProduit.Products.Item(i).PartNumber
        For j = 1 To lnn
            If stempPartNumber = sPN(j) Then
            lCount(j) = lCount(j) + 1
            monProduit.Products.Item(i).Name = stempPartNumber & "." & CStr(lCount(j))
            bExist = True
            Exit For
        End If
    Next
    If bExist = False Then
        lnn = lnn + 1
        ReDim Preserve sPN(lnn)
        ReDim Preserve lCount(lnn)
        sPN(lnn) = stempPartNumber
        lCount(lnn) = 1
        monProduit.Products.Item(i).Name = stempPartNumber & "." & CStr(lCount(lnn))
    End If
    bExist = False
Next
lnn = 1
ReDim sPN(lnn)
ReDim lCount(lnn)
sPN(0) = ""
sPN(1) = ""
lCount(0) = 0
lCount(1) = 0
    If monProduit.Products.Item(i).Products.Count > 0 Then
        For j = 1 To lPartNumberCacheSize
            If sPartNumberCache(j) = stempPartNumber Then
                bExistInCache = True
                Exit For
            End If
        Next
        If bExistInCache = False Then
            lPartNumberCacheSize = lPartNumberCacheSize + 1
            ReDim Preserve sPartNumberCache(lPartNumberCacheSize)
            sPartNumberCache(lPartNumberCacheSize - 1) = stempPartNumber
            Set otempProduct = monDocument.GetItem(stempPartNumber)
            Call fSetProductName(otempProduct, monDocument)
            On Error GoTo 0
        End If
    End If
Next
End Function
Marc
Hi MarcL68,
My script for renaming instances works fine.
It's adding the fixes again!!
