Debulk before prepreg compression molding
I 'm currently designning a debulk process inside our factory. The molding process use is a compression molding in close mold. The material use is Newport USA material. The lamination is simple and it is around a core material for a sporting good application.
I would like to know what is the pressure that I should target (specified) during the process? What is the time a should leave my part into the debulk process?
Do you have any orther process createrias that I should add to my concept (ex: breather to leave the air bubble trap leave my system).
Thank for the advices!
