Radius value in defining Membrane(with multiple radius)-Tire
Hi All
I am from tire domain,
In case defining of tire Embedded reinforcement wire(Body ply- defined as membrane in Abaqus), what should be the radius value.
As the membrane element contains multi-radius(see attached pic), what radius should be defined.
If any one from tire domain, plz help to get solution.
