Pumps test stand
Pumps test stand
Is it advisable to have a common suction line from a tank based on the largest size pump suction pipe then a manifold where the individual pump size to be tested at a time is connected and similarly with the discharge line back to the tank? Also, should there be a common suction and discharge pressure gage or it is better to install individually for each including flow meters in the discharge side?
