aluminum epoxy for cast crankcase
I was fortunate enough to be one of the ones that purchased this specific 22 hp engine that has a documented problem of a bolt backing out of the counterbalance and cracking the crank case.
Now to save a 1700 dallor investment i want to seal that crack with an epoxy, because several places tha weld stated it would be pot luck as they do not know the contents of the aluminum.
Looking for a recomendation for this application. It would be placed on the outside, crankcase produces vacuume not pressure so sucking air in the crack would be concern not visa-versa. This is small, hair line cracks. Oh as I just said, about vacuum, I wander while oil came out? all advise welcom.
RE: aluminum epoxy for cast crankcase
