How do you estimate size of beam and column ?
I would like to know the method that I can Estimate proper size of beam and column before I start modelling. is there any sample for that ?
RE: How do you estimate size of beam and column ?
statics
Gut level experience, but to get that, you have to run as few numbers a few times...
So, start with statics as WillisV said.
Mike McCann
MMC Engineering
I use span/depth & height/width ratios - there are a few good books around with this information. my grad manual has a few starting points, but you will need to do more research and numbers to develop to a acceptable level. thread507-267373: Grad Manual PDF
http://www.nceng.com.au/
"Programming today is a race between software engineers striving to build bigger and better idiot-proof programs, and the Universe trying to produce bigger and better idiots. So far, the Universe is winning."
code provide minimum depth of elements such as slabs,beams according to its span to avoid excessive deflection.
column, you can estimate load of column by area method without analysis and substitute in a very simple equation by loads and assuming reinforcement ratio,then you can get concrete area.
