Units in value fields
When modelling in 3D I always turn off units in value fields because it's just so much quicker that way. However, when I make my drafts I have to remember to turn the units back on or else the weights will not show their units in my BOM.
Besides remembering, is there a trick or a macro that will enable untis in value fields in draft environment and disable them in modelling environments?
Griffin
RE: Units in value fields
Can't you just save it in your templates that way?
--Scott
www.wertel.pro
Unfortunately its a user setting not a template setting.
We could do with a qualifier the opposite of /NU (no units) for property text so that you can make sure that units display in a BOM.
Enhancement request anyone?
bc.
Core i5-3570 @3.4GHz , 8GB RAM
Quadro FX4600. W7 Pro 64-bit.
