Unable to add component
In Modeling mode, in a assembly file, with assembly checked
When i try to add any component, it says
"none of the selected parts can be added as component.
An object was found null or forbidden."
previously i had no problem adding.
Program version: NX8.
Seth
RE: Unable to add component
I suspect that you will need to take this up with GTAC.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Actually i solved it by simply ,restarting NX and re-tick the assemblies at Start icon.
Thanks anyway, seems to be bug on the file itself and not the program but other project could still add component.
Seth.
