Hydrotest Material for 32in Pig Launcher & Receiver_BPL : BALL VALVES
Dear All,
Am looking for BALL VALVES for Hydrotest Material for 32in Pig Launcher & Receiver_BPL.
Would highly appreciate if somebody can help me out in finding an potential supplier URGENTLY.
We're based in UAE
Inquiry :
Item Specification Unit QTY to be procured
Size
(in) Spec.
Ball Valve (A 105) 6 150# RF Nos 8.00
4 300# RF Nos 20.00
Ball Valve (A 105) 2 300# RF Nos 8.00
2 300# RF Nos 8.00
1 300# RF Nos 4.00
Ball Valve (A 105) 2 NPTF 6000 PSI Nos 12
1 NPTF 6000 PSI Nos 8
1/2 NPTF 6000 PSI Nos 2
Weldolet (A 105) 2 #3000 (NPTM) Nos 8.00
1 #3000 (NPTM) Nos 4.00
PIPE A 106GR B SMLS 2 SCH 40 MTR 5.64
We're based in UAE
Inquiry :
Size
(in) Spec.
4 300# RF Nos 20.00
2 300# RF Nos 8.00
1 300# RF Nos 4.00
RE: Hydrotest Material for 32in Pig Launcher & Receiver_BPL : BALL VALVES
I can't even tell what size you're looking for. Is size the one after the spec and before the space.
What in that list is 32"? The weld-o-lets?
Or are you telling us you can't find a 2" 3000# weld-o-let
Do you want 8, EACH, 6" DIAM., VALVE, BALL, ANSI#150, RF FLANGES, ASTM A105
Good thing you're not looking for 8.45 of them.
Maybe nobody's quoting because you confused them.
Independent events are seldomly independent.
Dear BigInch,
First of all thanks for enlightening me, Please bear with my ignorance.
Below is refined information for the same and hope it makes sense this time :
1 Ball Valve 6" Floating ball valve full bore rating 150# flanged RF body & ASTM A105 S/S Trim C/S C/W Lever Operated Carbon Steel
A105 6" 8
2 Ball Valve 6" Floating ball valve full bore rating 300# flanged RF body & ASTM A105 S/S Trim C/S C/W Lever Operated Carbon Steel
A105 4" 20
3 Ball Valve 2" Floating ball valve full bore rating 300# flanged RF body & ASTM A105 S/S Trim C/S C/W Lever Operated Carbon Steel
A105 2" 16
4 Ball Valve 1" Floating ball valve full bore rating 300# flanged RF body & ASTM A105 S/S Trim C/S C/W Lever Operated Carbon Steel
A105 1" 4
5 Ball Valve 2" NPT Female x Female Reduced Bore Ball Valve 6000psi Material : A105 Carbon Steel
A105 2" 12
6 Ball Valve 1" NPT Female x Female Reduced Bore Ball Valve 6000psi Material : A105 Carbon Steel
A105 1" 8
7 Ball Valve 1/2" NPT Female x Female Reduced Bore Ball Valve 6000psi Material : A105 Carbon Steel
A105 1/2" 2
8 Weldolet 2" NPT male x Female 3000psi Material : A105 Carbon Steel
A105 2" 8
9 Weldolet 1" NPT male x Female 3000psi Material : A105 Carbon Steel
A105 1" 4
This is an engineering website, not purchasing, so you'll need a bit of luck here.
At least they can understand what you want now.
