Creo 2 - Problem with Swept Blend
Trying to use the Swept Blend tool to bind those two areas marked in gay colors (Binding a square sketch and a circle sketch), but seems like Creo is trying to connect the opposed face of the square area... something like that...
I had to Add two Blend Vertex
In 3ds max, for those who know it, I could "invert normals" and the thing was fixed, but here we don't seem to have a similar tool.
https://www.dropbox.com/s/bzmxry0588h4pwf/ProeProb...
Should I not be using Swept Blend for this ?
Any config to change ?
RE: Creo 2 - Problem with Swept Blend
More information:
- I did not assign any blend control;
- Both Tangencies are free, whether in the future I would like to control the path those areas take to connect eachother;
- Tried do switch every arrow I could find, but the problem remains.
One other option is to use the "boundary blend" tool but that would require merging and solidifying for applications to solids. I think if you modify the circle sketch to include 4 segments and get rid of the automatic added vertices it should work...just remember to align the start points of the sections.
Hope that helps and good luck,
- J -
