Manufacturing process of steel tank with butyl diaphragm.
Can anyone tell me about the procedure followed for applying the butyl diaphragm in the steel tank (Pressure vessel). I am unable to find the process used for pinching that butyl rubber diaphragm between the wall of pressure vessule and the hoop ring.
Need help ASAP.
Need help ASAP.
RE: Manufacturing process of steel tank with butyl diaphragm.
does the hoop ring is installed at lower temp and then there is interference fit between thd butyl rubber and the ring.. i dont know, i am just guessing.
