Search for an Instance name in a product
Hi Guys,
Another little problem I can't for the life of me figure out.
I want to search for a specific Instance of something, for example "Apple.2". I have a SearchString Var with "Apple.2" in it.
How do I then search for that in a product?
I've tried:
oSelection.Search "CATAsmSearch.Name=SearchString,all"
oSelection.Search "'Assembly Design'.Product.'Part Number'=SearchString,all"
And numerous others off the internet with no success.
Thoughts?
Thanks!!
RE: Search for an Instance name in a product
(Name='Apple.2' & (((((((((('Product Structure'.Product + 'Systems Routing'.Product) + 'HVAC Design'.Product) + 'Assembly Design'.Product) + 'Waveguide Diagrams'.Product) + 'HVAC Diagrams'.Product) + 'Systems Space Reservation'.Product) + 'Process Applications'.Product) + 'Tubing Diagrams'.Product) + 'Plant Layout'.Product) + 'Piping and Instrumentation Diagrams'.Product));all
You can decrease number of considered types of product , for e.g. only to product structure and assembly design
(Name='Apple.2' & ('Product Structure'.Product 'Assembly Design'.Product));all
LukaszSz. Poland, Warsaw University of Technology, Faculty of Power and Aeronautical Engineering : MEchanical Engineering. BsC - 2013
What would the full string be?
oSelection.Search (Name='Apple.2' & ('Product Structure'.Product 'Assembly Design'.Product));all
[That doesn't work :p]
(I should have said I want to select the found item!!)
Many Thanks!!!!!
CODE -->
oSelection.Clear
Dim InstanceName 'as String
Dim SelectionQuery 'as String
InstanceName = "Przekladnia_MASTER.1"
SelectionQuery="(Name='"& InstanceName &"' & (CATProductSearch.Product + CATAsmSearch.Product)),all"
oSelection.Search SelectionQuery
Dim FoundedInstance 'as Product
MsgBox oSelection.Count & " Items of" & InstanceName &"has been founded"
Set FoundedInstance=oSelection.Item(1).Value
Hi Guys.
Thanks, both methods work!!
