Grease pumping
Grease pumping
We have a problem with pumping high viscous NLGI 3 grease. We need to feed a cartridge filling line with constant flow and constant pressure. This first problem is solved by using an air operated double diaphragm pump that feeds an progressive cavity pump.
Now we have another problem. We get air in the system. I assume that the grease is full of air becuase airpockets. We have a bleeding valve between the two pumps. However, even if we open the valve we still cant get the diaphragm pump to get any product. It pumps out air and sucks it back in thorugh the outlet.
We solve the problem if we open up the pump and fill it with grease. Then it runs for a while untill it starts suckin air again. I am thinking it might be that the balls are stuck because of the viscous product and it both blows and sucks air from the outlet. Nitrile balls and membranes.
Filip
Filip
RE: Grease pumping
Valuable advice from a professor many years ago: First, design for graceful failure. Everything we build will eventually fail, so we must strive to avoid injuries or secondary damage when that failure occurs. Only then can practicality and economics be properly considered.
RE: Grease pumping
With the grease, I would want to use spring loaded check valves and be sure to use a very low cycling rate on the diaphragm pump. Am I correct in assuming some significant cost or space constraints dictate the use of the diaphragm pump rather than another type?
RE: Grease pumping
How are the two pumps in series being matched, i.e. if the PC pump is trying to pump even a little bit faster than the diaphragm pump can deleiver then it will pull a vacuum and allow air in from somewhere?
With viscous material a little bit of heat never went astray - is it possible to heat the raw material up, even to 30 or 40 degrees?
RE: Grease pumping
The PC pump is continuously "puling" the grease but there is pulsation flow from the AOD pump. There will be a pressure drop between the 2 pumps in between the strokes of the AOD pump. The discharge check valve of the AOD will not see back pressure to close it unless you spring load it.
RE: Grease pumping
Depending on the piping and arrangement details of your system, it may make sense to install a diaphragm-type pulsation damper near the suction of the diaphragm pump, too. As with the pulsation damper for the discharge side, it, too, should be relatively very large.
RE: Grease pumping
Next thing:
Some of you touched the point I am wondering about. If we will have pulsation after the PC pump because of the setup. We are running the AOD Pump at 3 bar. The PC pump have to push at a constant pressure of 5 bar into a dosage pump on the cartridge filling machine. We have an adjustable bypass that takes care of the constant pressure.
You think we need a pulsation damper between the AOD pump and the PC Pump?
We have this setup with two pumps because the PC pump was not able to do the job by itself.
RE: Grease pumping
