Concrete Coring Tests
When you do coring tests on concrete like columns. What is the best replacement materials for the 50mmx100mm holes? Concrete is 4000 psi. What compressive strength results do you consider failure after concrete is 3 month old?
RE: Concrete Coring Tests
FAQ507-1575: How to Evaluate Concrete Tests per ACI 318
