Equivalent Steel Section
I have a soldier pile walls with concrete infilled stell pipe piles. I want to replace the steel pipes (filled with concrete) with an I beam section. How can I for=und the equivalent size of the I beam. Should it be the memont of inertial criteria or else? Is there an online conversion table? Thank you.
RE: Equivalent Steel Section
Brian C Potter, PE
http://simplesupports.wordpress.com
http://www.roymech.co.uk/Related/Construction/Conc...
