cfrp and steel yield
hi all,
when we use the cfrp Sheets for shear strengthening for concrete beams.....the beam will handle more load......but would that delay the longitudinal steel yielding or not.....i tried to analysis a concrete beam with and without cfrp.....but the longitudinal steel yielded at the same load.....is that is ok?
thanks
thanks
RE: cfrp and steel yield
