Reinforcing Splice "Lap Class" Explanation
I've always used the standard ACI 318 equations for determining tension and compression lap splices. I see a lot of the newer material (specifically the 2002 CRSI Design Handbook) uses something called "Lap Classes" types A and B. Type "B" being either worst case or more conservative depending on the definition. CRSI does not define what these classes are. I could not find the definition anyway.
Could somebody please explain what exactly what these classes mean and how to determine what class to use. Thanks.
RE: Reinforcing Splice "Lap Class" Explanation
The requirement is to "encourage the location of splices away from regions of high tensile stress."
