Cloning Assembly with parts not loaded - Clone
Hi, I use NX6.0.5.3 and TC 8.3.2.3
I have an assembly and I get an error when I try to clone it. The part is in TC but I don't think that is the reason.
When I open the assembly and do info/part/loaded parts. I see that there are parts that do not load. These parts do not show up in part navigator. Could this cause a cloning error? I do not want to load these parts as it may update and change my model. How do I get rid of these "phantom" references to the "missing" parts
RE: Cloning Assembly with parts not loaded - Clone
I have a feeling that the parts that did not load may be part of a WAVE link or body promotion.
Run part cleanup with the "Clean interpart links" and "Delete unused objects" options. This should get rid of the "phantom" references.
www.nxjournaling.com
There are a broken links in the part and when I us info on the link features I see
Broken (Parent Geometry Is Missing)
But how do I fix this so I can clone?
Can you load the part that is missing ?
The part clean up did not work.
I ran it with all but the bottom 3 that say (Use Caution). Then I did a Force Save All. Closed all.
I say the views were checked out in TeamCenter so I CHECKED the TC views IN. Opened the past ran CLEAN UP and Force Save All. I ran info/part/loaded parts. I see that there are parts that do not load.
Closed all restared NX and cloned. The clone still failes.
If you have broken links, the part cleanup won't work. You'll have to fix the links.
I've seen situations where the assembly "held" a reference to a part that was deleted out of it, which caused the clone operation to fail. The part cleanup trick worked in that case.
It's a good idea to right all wrongs in an assembly before cloning it. Make sure that everything is up to date, that no links are missing, and everything is in a good working order. Otherwise you will clone problems. If you are able to clone at all.
