Clocking gear teeth with an asymmetrical feature
I need a little help here.
How would I go about ensuring that the flat on the internal D-hole is oriented to the gear tooth pattern? We are referencing an AGMA spec to dictate the geometry. I don't know the number of the spec. My assumption is that the tooth geometry--and tolerancing--is dictated by the spec and the spec probably doesn't use profile to tolerance the tooth geometry. If we were to define a tooth with basic dimensions then we could get simultaneous requirements to apply but we'd rather have the spec define it. Any ideas?
Before you guys slap me around too badly, I have no real experience with gears so have a little mercy on me.
John Acosta, GDTP S-0731
Engineering Technician
Inventor 2013
Mastercam X6
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
RE: Clocking gear teeth with an asymmetrical feature
This is what I was able to find in Genium Manual:
Frank
Inventor 2013
Mastercam X6
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
CH,
I agree a tooth can be used as a datum, I do not think it is generally, functionally speaking, a primary datum.
Frank
Please see my sketch as "intentionally incomplete"
I am not setting primary datum, just giving example what the datum may be.
I would tend to do just what powerhound has done, in the OP, and added CH's dim accross a tooth and use a position of the tooth at pitch line. Face(I assume) is primary, bore is secondary and flat is tertiary. I see this as a functional definition (assuming I have correctly read how it functions). Bore could be primary if face is not fumctional :)
Frank
I know that simultaneous requirements is not the only way to control things, it is just one easy way that I can think of. Your example is another way.
Inventor 2013
Mastercam X6
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
It is really nice to dimension everything from the same datum framework, and, as a bonus, get everything glued together by simultaneous requirement without extra effort.
But sometimes you have to make a choice to control one feature WRT other.
There was a thread on this forum about practical ways to clock gears:
http://www.eng-tips.com/viewthread.cfm?qid=111643
The posters generally agreed that it is better to cut teeth first.
So, using tooth as a datum was not exactly part of my evil plan.
I agree with pmarc, that was also my point about the proposed Genium solution, it is not really up yo date.
When you make tooth a datum, you imply that said tooth is somehow more important than others.
