A356-T6 Aging at elevated temperatures
I'm working with A356-T6 Al that has a normal operating temp of 100 degrees C but can go up to 200 degrees C for at most 10 minutes at a shot. My ASM Book Aluminum Alloy Castings Properties, Processes and Applications book has a table (D4.26) that shows 356-T6 material properties at elevated Temps/times and after being brought back to room temperature. At 200 Degrees for 1/2 hour I should be fine and it should have a higher Tensile Strength and Yield Strength after it returns to room temp. There is a chart for A356-T6 (D4.29) but it neglects to shown the material properties after it has been cooled. Is the chart for 356-T6 representaive of the general results after cooling for A356-T6?
Also are the temperature effects additive? If it spends 5 minutes everyday at 200 degrees C for a year is that the same as being held at 200 degrees C for 30 hours?
I don't beive it is but don't really know. If it is additive then the tensile and yield stregth will be reduced.
Any thoughts?
Thanks, Will
Any thoughts?
Thanks, Will
RE: A356-T6 Aging at elevated temperatures
