Welding a dowel/pin to a wide flange
What symbol would you use to show a dowel being welded to a flange of a beam? I am showing a fillet weld with the all around symbol, not sure thats correct.
Also, for the weld strength, what calc would you use? Just take the length of the weld? its a shear load on it.
RE: Welding a dowel/pin to a wide flange
You could specify a "Nelson" stud...a resistance welded stud if you have multiple ones to do.
http://www.icc-es.org/reports/pdf_files/ICC-ES/ESR...
Anyway, thanks, will specify a fillet weld.
