Driving dimension depending on reference dimension.
Hello all,
I'm using NX8.0 and i want to create a driving dimension that is for example half the size of a reference dimension. Problem is that I dont know the name of the reference dimension, so i cannot do it with a formula.
Also when i create a new driving dimension, you always get a dropdown menu with following choices: measure, formula, function or reference.
If I choose here the option reference than i can select another dimension but than NX doesn't take any reference dimension.
Can somebody help?
Thx
RE: Driving dimension depending on reference dimension.
First question ) Try to create a ligne between the 2 points of your reference dimension then you can measure it and add the result in a formula
2nd Question) Select a feature when the dropdown menu appear
I hope this help
Didier Psaltopoulos
http://www.psi-cad.com
So-called 'Reference Dimsnions' are NOT accessible in terms of their being reused by an expression/driving dimension. They are just that, for 'Reference' ONLY, not unlike a dimension placed on a Drawing. Granted, they update if the model changes, but they are not tied to an expression value.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
