Metal that changes color upon impact
Does anyone know of a metal that changes color when struck and eventually goes back
to it's original color? An example of this is a material that is as strong as steel
and when you strike it with a hammer it darkens at the spot of impact and then
returns to its original state after a short period of time (say < 30 seconds).
I'm not even sure if such a material exists that is strong like steel. I know
that piezoelectric materials change color under stress but they're not very strong.
I need something that can withstand a powerful impact.
Victor
RE: Metal that changes color upon impact
To elaborate, how about a thermochromatic coating. A decent impact should create localized increase metal temperature that should show up as a color change.
How big an impact? I've seen thermal effects on wrecking balls bashing steel reinforced concrete, but that's a different regime and they faded in less than a couple of seconds.
Even with ceramics, which have very poor thermal conductivity, short duration thermal effects fade within about 20ms; this is with a 30mJ laser with 11-ns pulsewidth, which is a peak power of 2.2 MW.
TTFN
The force would be about 600N which is about 1350 lbs. A coating is not a bad idea as long as it is tough
enough to withstand repeated impacts (1000's).
Victor
Interesting idea. The problem is that I can't really change the dynamics of the device being struck
by adding circuitry although it is something to consider.
There are optical units that don't actually touch the item being measured. I don't know what the cost is though.
Stonecold
I would imagine that the force is spread over 0.5 - 1 square inch. The application is confidential at this
point so there is not much I can say until I get a patent application in the works. I'd be more than happy
to speak with someone via private email though (vavalencia --at-- gmail.com) if you need more details.
Also, a big thanks to all that have participated in this discussion. I really appreciate the help!
Victor
