deleting multiple items in drawing mode - Pro/E 2001
We have recently switched from Pro/E 2000i² to 2001. In drawing mode, the menus are different. I can't figure out how to select multiple entities so I can delete them at the same time. I know I can hold down "shift" and select them one by one, but that takes too long. I want to be able to "pick many" and select them all, then delete them all. Is this possible in version 2001?
RE: deleting multiple items in drawing mode - Pro/E 2001
There is a button you can put on the toolbar "delete many objects".
I have been struggling with this for an hour.
Go to - EDIT - CUT-PICKMANY-Create a box which will include all the entities which you want to delete - DONE.
Also, you can pick entities one by one under PICK option.
Cheers..
Yogesh Birari
