Stub Reference Error
NX8.5
An engineer has done a "save as" on an assembly and changed a few parts. They now recieve the folloing error when loading both Part and drawing.
The following files could not be loaded causing this open to fail:
(part no) - an expected stub reference was not found (probably during deletion)
c:/temp/(longnumber-NX_nav.plmxml - Failed to load part
We have never seen this before and it seems to have cirrupted all version?
Adam
Adam
RE: Stub Reference Error
I have not seen the error before.
Tomas
They suggested that it was caused by a partially unloaded attribute.
We got the assembly creator to load the assembly and try adn resave
This seemed to solve the issue
They also suggested to do a part clean up on each part / assembly
Cheers
