Reference Set
Reference Set
Hi all,
I am using the below code to create Reference set "S" and to move all the assembly components to that reference set.
I need a correction in this journal. It is collecting all components and bodies and adding to s reference set.
But I need to eliminate para solids whose extension (.x_t) or if it is not possible then, it can eliminate all features and bodies from part
navigator only. But, it should collect all assembly components which are in assembly navigator and to add in reference set s.
Thanks in advance.
Thanks in advance.
CODE -->
Option Strict Off
Imports System
Imports System.Collections.Generic
Imports NXOpen
Module Module1
Sub Main()
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim markId1 As Session.UndoMarkId
markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Create New Reference Set")
Const newRefSetName As String = "S"
Dim found as Boolean = False
Dim myRefSet as ReferenceSet
'check to see if reference set already exists
For Each myRefSet In workPart.GetAllReferenceSets()
If myRefSet.Name.ToUpper() = newRefSetName Then
found = True
Exit For
End If
Next
Dim referenceSet1 As ReferenceSet
If Not found Then
'create new reference set
referenceSet1 = workPart.CreateReferenceSet()
referenceSet1.SetName(newRefSetName)
Else
'use the existing reference set
referenceSet1 = myRefSet
End If
'add all components (existing and future)
referenceSet1.SetAddComponentsAutomatically(True, True)
'create list variable for solid bodies
Dim mySolids As List(Of Body) = New List(Of Body)
'workPart.Bodies collection contains both solid and sheet bodies
'filter out solid bodies and add them to the list
For Each solid As Body In workPart.Bodies
If solid.IsSolidBody Then
mySolids.Add(solid)
End If
Next
'add solid bodies to reference set
referenceSet1.AddObjectsToReferenceSet(mySolids.ToArray)
End Sub
Public Function GetUnloadOption(ByVal dummy As String) As Integer
'Unloads the image when the NX session terminates
GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination
End Function
End Module
Thanks & Regards,
Sam
RE: Reference Set
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
