Using TCCS with NX
Using TCCS with NX
We need to use a proxy to connect over the internet from a NX client to a Teamcenter server. I think that this can only be done by TCCS.
I have installed TCCS. TCCS starts and connects to the fcc without any problems.
But when I try to start NX using: ugraf -pim=yes -u=username -p=password -tccs_env_name=our_env_name
NX gives a messagebox saying: SOA: Failed to get the TCCS Environment. Received TSP Exception with no message string.
Does anyone have any ideas on what the problem could be?
/Erik
/Erik
RE: Using TCCS with NX
Starting the tccs manually with starttccs.bat showed:
ERROR - None - 2013/05/08-08:55:11,554 UTC - A0165 - Mismatched TCCS_CONFIG_HOME
Client: C:\ProgramData\Siemens\cfg\tccs
TCCS:
Setting the environment variable TCCS_CONFIG_HOME for starttccs.bat solved it and now NX is connected to TC via TCCS and proxy.
Also the documentation for TCCS_CONFIG_HOME is wrong in Tc9, see PR #:1898782.
/Erik
It seems that the FMS uses HTTP 1.1 to communicate and our proxy does not support that.
Does anyone know if it is possible to change it to HTTP 1.0?
set UGII_UGMGR_COMMUNICATION=HTTP
Best regards,
Michaël.
NX7.5.4.4 + TC Unified 8.3
Win 7 64 bit (Intel(R) Xeon(R) CPU X5650 @2.67GHz)
24.0 GB
NVIDIA Quadro 4000 + NVIDIA Tesla C2050
HTTP 1.1 might not be the problem after all, even though the proxy error message led me to believe that.
The actual error from the proxy is "HTTP/1.0 400 Bad Request"
This is the request from the FCC/TCCS:
GET http://our.server.name:4544 HTTP/1.1
User-Agent: FMS-FCC/9.1 (bd:20120302)
X-Ticket: 70def0a3a8d721e782e55ce41a954cda3a7c9a24856dcac07f04b8ebea6bcac8v1004F00000000000012ae00001d5fa53ca45a2013%2f05%2f15+13%3a41%3a25-1522752422+++++++++++++++++++++soa+++++++++++++++++++++++++++++01030000000ca53ca45a++++++++++++%5cengineering_50780ad1%5c000020__ug__cvi06wo4s729l.qaf
X-Policy: NX
Proxy-Connection: Keep-Alive
Host: localhost:8080
At the end of X-Policy: NX there is a NULL. Checking the TCCS log with level debug reveals that it sends "X-Policy: NX[0x0][\r][\n]". 0x0 is NULL and this makes the proxy throw an error.
