ACS355 Overvoltage fault
Does anyone have suggestions for ACS355 VFD that intermittently faults on overvoltage?
At the time of the last fault voltage was 831 volts. This fault is happening once every couple of days.
RE: ACS355 Overvoltage fault
What is the load? What is the voltage? What HP? Do you ramp down the speed quickly?
Bill
"Why not the best?"
Jimmy Carter
Blower Motor
497VAC Input
20hp
30 seconds deaccel time
DC bus voltage during running is observed around 680
Do you have an idea of what is happening when it trips on OV? As in during Run, during Decel, while Off?
"Will work for (the memory of) salami"
