end offsets at beam support
How do you adjust the end offsets settings in Etabs so the beam support would have zero moments? The default is non-zero moments even from new installations.
RE: end offsets at beam support
maybe are you referring to the end-releases? End length offsets do not result into zero end moments...
Analysis and Design of arbitrary cross sections
Reinforcement design to all major codes
Moment Curvature analysis
http://www.engissol.com/cross-section-analysis-des...
