ASSEMBLY_SECTION_LARGE_ASSY_NX8.0.2
I have opened a large assembly under the light weight representation and use the Section command(view-section-new section).
The output in the 2d section curves varies lot.How to minimize this variation in light weight mode?
When I change to Exact mode then the results are OK.I have attached the supporting image here to explain the same.Also,what impact/performance/memory issues it creates if I change always the Excat mode during the section.
Thanks and regards,
Mathi Krishnan.
RE: ASSEMBLY_SECTION_LARGE_ASSY_NX8.0.2
Any answers for this query?
Mathi K
