Drawing Text - Set Anchor mode to Global
Could somebody let me know how can we set the Anchor mode of a drawing text to Global.
[img D:\Text - Anchor Mode.jpg]
Not getting any API reference for this but seen a macro (catvbs) which does the same.(attached for reference)
Maddy
RE: Drawing Text - Set Anchor mode to Global
Try to add a watch to Text and see what is happening when you are playing with different values for Text.AnchorPosition . You have a test file ( r18 ) also attached.
CODE --> catvba
Sub CATMain()
Set drawingDocument1 = CATIA.ActiveDocument
Set Sheets = drawingDocument1.Sheets
Set ActiveSheet = Sheets.ActiveSheet
Set Views = ActiveSheet.Views
For i = 3 To Views.Count
If i <> 2 Then
Set View = Views.Item(i)
Set Texts = View.Texts
For j = 1 To Texts.Count
Set Text = Texts.Item(j)
        Text.AnchorPosition = 28
Next
End If
Next
End Sub
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
Thanks ferdo, Infact i almost forgot it to try out.
Maddy
