RSLogix 5000 module profile
I have a VFD, Delta C2000 series, with an Ethernet/IP adapter and I've successfully
generated its EDS file. Delta, apparently, doesn't supply an RSLogix 5000 module profile and
doesn't supply I/O data information to configure a generic module.
I have RSLogix 5000 V16 Standard Edition. Is there a way for RSLogix 5000 to utilize EDS files?
Maybe in the the newer versions or upgraded editions? Or, can RSNetWorx for Ethernet/IP add the
module to the ENBT using the EDS?
Last resort, does anyone have I/O data for this drive, to set up a generic module?
Thanks in advance.
Thanks in advance.
RE: RSLogix 5000 module profile
