slope stability software
I am a geotech engineer and in the market to buy some easy to use software for slope stability analysis. Hoping someone has had a good experience with a certain software and would recommend it. Also with this software, I need to analyze the stability of temporary excavations on jobsites.
RE: slope stability software
- GeoStudio with the SLOPE/W module is a very easy to use software
- TALREN a french software that is easy to use, but the interface isn't very sofisticated.
If you want a more sofisticated software, you have to look for a finite elements one.
- Plaxis 2D gives the stress and strain in every soil point, it is very usefull espicially to analyze the staged phases like temporary staged excavations.. it can calculate many scenarios in one project.
• Did you say you were to analyze the stability of temporary excavations on job sites? Then the best option for you will be Plaxis (now there’s Plaxis 2D)
• I only know two of the popular software for slobe stability and these are Oasys and Plaxis 2D.
• Oasys would be the most helpful software for two dimensional slope stability analyses.
• Why don’t you try Oasys or SVSlope? Both of them are good. You can also try Plaxis 2D.
