Create Group with Node Selection
Hello everybody,
I have to programme a plotting programme in NX. The problem is that we only need plots of the gluing surfaces. So I wanted to put a group consisting of the Nodes of the glue surface. Like you can do with the Identify Function when you're in the results mode. I have tried several things, e.g. letting the programm read the Nodes by an xml file or making a selection of nodes. But nothing worked. Does anyone of you have an idea how to put the Nodes in a group in journaling?
Thank you for thoughts
