UFD - Origin and Orientation
I have created an User Defined Feature. It is a Sketch for undercuts. I heve NX7.5
The problem I have is this : at inserting where I needed, it is always coming in position 0,0,0 and I am not able to put it where I want it. So how can I define the Origin and Orientation for UFD ?
RE: UFD - Origin and Orientation
The problem I have is in UDF Wizard - References - Add Geometry, so at creating the insert reference for the UDF. If I create a Horizontal and a Point (for example) then before using the UDF in my application I have to create the same Horizontal and Point
